I formatted my card into EXFAT but now phone and PC running W7 wont regognize it anymore.
If I plug it in my pc I hear that sound but it will not pop up as a drive and device management it is visible as a usb card but my phone doesn’;t see it at all.
Please do help me it cost 80 euros and I m scared I cant use it anymore.
. . . but now phone and PC running W7 wont regognize it anymore.
You may need a Windows patch/update on your computer to recognize the newer format, or your method/software to re-format it was faulty. Your phone may or may not support exFAT, depending on how old it is. There may or may not be a patch/firmware update for it to do so. Check with your phone mfg. website.
