Anyways I load up some songs. I notice that for some songs, when displaying the song title they have a number next to it. So it’ll display something like 1-Song. I’m pretty sure it’s the track number. However, I notice for some other songs it doesn’t display this track number.
My guess is the tracks showing as 1-Song are being displayed by filename.
If you are using MP3 files, make sure the tags are in ID3 version 2.3 using ISO8859 character set. Sansas don’t like other versions much, particularly v2.4. Although v2.4 is being fixed by a firmware upgrade at some point.
Mp3Tag(*) can help here - In Tools->Options-Tags->Mpeg, set it to read all tags, remove all tags, and write only ID3v2.3 & ISO8859.
Select all tracks in a directory in your library, hit save, and it will convert your tags. Try it on a test directory first though…!
If you set ‘Subdirectories’ under the ‘General’ setting, it will do your entire library in one hit.
(*)Statutory Notice: Other tagging tools are available
Message Edited by daytona955 on 12-03-2008 10:59 PM
Message Edited by daytona955 on 12-03-2008 11:27 PM
