MP3 wont play certain songs, how do I fix?
When playing songs the player will skip some songs after only a few seconds and the player is fairly new, the brand isn’t marked, but the information on the back is this:
Model: MB07
Capacity: 16GB
Input: 5V=500mA
RoHS FC CE
MADE IN CHINA
Hi @Pitfall,
Solution: 1. Check if a high song bitrate can cause MP3 playback to fail. Only computers support high bitrates, and there are many different bitrates of MP3 files for the same song. 2. Check if there was a transmission error during song download, resulting in incomplete files. 3. Check if the song has been downloaded completely. If it is incomplete, please delete it and download again. The Tunelf Deezer Music Converter for Mac and Windows allows you to download Deezer songs and play them on any device or platform you want through personalized output parameters such as format, bit rate, sampling rate, and channel.
