Micro SD Adapter needed to unlock write protection on micro SD card?
My 2gb and 8gb micro SD cards are corrupted, and I am unable to access the cards either through my phone or through a USB card reader I recently purchased. I’ve attempted a format through Windows, but it was unable to format. I tried formatting through SDFormatter, but an error says the memory card is write-protected, and to release the write-protection switch.
I understand that a Micro SD card --adapter-- has a mechanical switch on the side for write-protection. However, I only have a USB card reader with no switches. The Micro SD card is plugged directly to the USB stick, and USB goes into the PC.
Now, is the adapter with the write-protection switch required in order to format a micro SD card? As if there is write protection on the cards that can’t be bypassed without the adapter and it’s switch? Or should I still be able to format the micro SD cards with my simple, switch-less USB card reader?
And I realize that this site has seen a lot of threads with similar titles, but nearly all of them point to the mechanical switch on the side of the adapter, and how it sometimes sticks, comes loose, or whatever. I never found a definitive answer to my exact problem.
Thank you.
What about reformatting it to exFAT, does it make a difference?
Why would you suggest formatting to exFAT??? :confounded:
That format is only for 64GB cards and larger.
:smiley:  Hola, Daelorr
Estimado Usuario
Disculpa, que te conteste este mensaje, después de dos meses, pero, es que recién lo vi, cuando estaba “navegando” por el Forum.
Me gustó tu manera inteligente de plantear el tema y sobre todo, que tienes “inquietudes” que te llevan, también a navegar por SanDisk.
Por lo tanto, estoy seguro, que verás esta respuesta, y supongo que “valdrá la pena”.
Así, que decidí, dedicarle a tu mensaje la tarde del domingo, para ver si puedo aportar algo sobre este tema.
El dilema del Cybernauta y su microSD segura
Entiendo que tú tienes una microSD de 2 GB y una microSDHC de 8 GB con “problemas”.
Veo, además, que tú nombras varios dispositivos, que originan confusiones y agregan “más problemas” todavía. Como ser: teléfono, Lector de tarjetas, adaptador para micro tarjetas y líos con interruptores (mecánicos, informáticos o electrónicos).
Sobre todo, hay “confusión de confusiones”, con la “Protección de escritura”.
   1-  Con respecto a tus dos microSD, todo lo que se me ocurre por ahora, como sugerencia, ya lo contesté en las dos respuestas que están en el siguiente link:
http://forums.sandisk.com/t5/All-SanDisk-USB-Flash-Drives/64-GB-MEMORY-CARD-NOT-RECOGNIZED-BY-MY-MOBILE-GALAXY-NOTE-II/m-p/323546/highlight/false#M8881
   2-  Fíjate, que yo ahí remarco, el detalle de no usar “Lector de tarjetas”, sino “adaptador de tarjetas microSD”, justamente para que la conexión sea directa y no se compliquen las cosas, agregando “problemas” a algo tan simple, como saber si la microSD funciona o no.
Parece sencillo, ¿verdad? (ja, ja, ja).
   2.1-  Lo que pasa, es que el adaptador, es un simple dispositivo “pasivo” (pues no tiene componentes electrónicos que amplifiquen o modifiquen las señales como ser transistores, etc.).
Y tiene, un interruptor mecánico, para sólo lectura, similar a la tarjeta SD.
   2.2-  En cambio, el Lector de tarjetas, es un dispositivo “activo” (que en su interior tiene miles de transistores, que están adentro de un “Circuito Integrado” o “Chip”).
Y este es, justamente, uno de los problemas, el que no te permite saber, si tu tarjeta funciona o no, o el que no funciona bien es el Lector.
   2.3-  Porqué sucede esto:
Primero, muy sencillo: pues estamos introduciendo un nuevo dispositivo, en la “cadena de probabilidad de errores”, que no es necesario, y es peligroso para la tarjeta, si ésta no es de muy buena calidad.
Segundo, porque la mayoría: (98%), son FALSOS y malas copias de los que sirven, como ser: SanDisk, Kingston y Encore (son las tres marcas que yo uso, otra no conozco).
Tercero, cómo diferenciar, el falso del genuino: abriéndolo, si, así es.
Por ejemplo, el lector SanDisk de microSD, (ese tan pequeño y hermoso, rojo coral y negro, parecido a la “Blade”), está preparado, para que lo puedas abrir con las uñas, con una simple presión (y paciencia).
En su interior, verás dos “cuadraditos” negros, que tienen un montón de contactos dorados.
Esos son los famosos “Chips”, la tecnología de punta del Siglo XXI.
Bueno, como ya sospechas, en los falsos, al abrirlos, verás que ¡no hay Chip!
Simplemente hay una gota de resina epoxi, que recubre un circuito pasivo (resistores, capacitores, etc.).
Y que te engaña al principio, hasta que no funciona más y te quema la tarjeta SD.
Entonces… te quejas de ella, en el Forum (ja, ja, ja).
Cuarto, pero otra aclaración: si tienes el original de excelente calidad, ¡es una maravilla!, pues con el conjunto (lector + microSD), (y así se inventó la Pendrive), tienes “una micro Pendrive de memoria variable”.
Quinto, resumiendo: como ya te habrás dado cuenta, entonces, en el caso de problemas con la microSD, para formatear, etc., conviene la conexión más directa a la computadora, lo que se logra con un simple adaptador y al puerto card de la Notebook.
   3-  La Protección de escritura: conozco tres casos sobre este tema, dos que los podemos instrumentar nosotros, y uno, que no depende de nosotros.
   3.1-  El primer caso: es el modo mecánico (con interruptor).
Como puedes ver en las fotos, es un simple interruptor que está a la izquierda/arriba (Lock) en las tarjetas SD. Y de la misma manera, está en el adaptador para las microSD, que es como una tarjeta SD hueca. También, parece que hubo hace años, Pendrives con interruptor mecánico, que se dejaron de fabricar. Yo nunca pude conseguir una, sólo la foto (Wikipedia).
Éste, es el mejor modo de acceder a PCs públicas sin riesgo de malwares, pues una vez que pones el interruptor en Lock, se convierte en sólo lectura y ningún virus podrá infectar la tarjeta SD. Y la microSD, la pones, en un adaptador (en Lock), y si la PC no tiene un puerto card, la pones luego, en un Lector por USB (de alta calidad) para tarjetas.
   3.2-  El segundo caso: es el modo informático (con software).
Se puede hacer de tres maneras: “tocando” una línea del Registro de Windows, con gpedit.msc, o con algún programita (free) que lo hace por ti y sin riesgo (USB WriteProtector 1.20, etc.). Pero, atención, esto sólo sirve para la PC en que trabajas, no para las UFD, pues no es nada más que un bloqueador de puertos de la PC. Cuando yo voy a usar una PC desconocida, antes de poner la UFD, bajo el programita de internet (correo o disco virtual), y entonces bloqueo los puertos USB, que quedan como de “sólo lectura”, para que los virus, no “me escriban” en la misma. Y ahí, veo si la PC es peligrosa, pues cuando hay virus, empiezan a aparecer popus engañosos, que me piden que quite la protección de escritura.
De todos, la mejor protección es la mecánica, pues hay paquetes de virus que te bloquean el registro y no queda fijado el bloqueo al puerto.
   3.3-  El tercer caso: es el modo electrónico (por falla en el Chip de la UFD).
Éste, es el que no podemos nosotros implementarlo, y tampoco por ahora, deshacerlo.
Como habrás visto en el Forum, hay muchas quejas por el problema: enojos, rezongos, gemidos, lamentos, lloriqueos, aullidos y propuestas “mágicas”.
Y sin embargo, por ahora la solución es muy simple: devolver la UFD y listo.
Disfruta.
Saludos, Alfred.
:smiley:  Hi, Daelorr
Dear User
Excuse me, that answer this message, after two months, but I just saw it when I was “surfing” on the Forum.
I liked your smart way to raise the issue, and above all, that you have “concerns”, that take you also to browse by SanDisk.
So I’m sure that you will return, and see this answer, and I guess " will be worth it".
So, I decided, dedicate a post, the Sunday afternoon, to see if I can contribute something on this topic.
The dilemma of the Cybernauta and your secure microSD
I understand that you have a  microSD 2 GB and microSDHC 8 GB with "problems”.
Also, I see that you name, several devices, which cause confusion, adding " more problems " yet.
Such as: phone, card reader, microSD card adapter, and messes with switches (mechanical, informatics or electronic).
Above all, there “confusion of confusion” with the "write protection”
   1-   Regarding your two microSD, everything I can think of for now, as  suggestions, I answered, in  two answers that are in the following link:
   2-  Look, I commented, detail not to use “card reader”, but if “microSD card adapter”, precisely so that the connection is direct and not complicate things adding “problems”, to something as simple, as knowing if the microSD, works or not.
There seems simple, right? (ja, ja, ja)
   2.1-  What happens is that the adapter, is a simple “passive” device (it has no electronic components that amplify or modify the signals, such as transistors, etc.). And it has a mechanical switch to read-only, similar to the SD card.
   2.2-   Instead, the card reader is an “active” device (which inside has thousands of transistors, which are inside an "Integrated Circuit " or "Chip”).
And this is precisely one of the problems, which does not allow you to see if your card works or not, or does not work well the reader.
   2.3-    Why this happens:
_ First _, very simple: because we are introducing a new device, in the “chain of errors probability”, which is not needed and is dangerous for the card, if it is not of very good quality.
_ Second _, because most: 98 %) are FALSE, and bad copies of: SanDisk, Kingston and Encore (are the three brands I use, other do not know).
_ Third _, how to differentiate the genuine the false: opening it, yes, that’s.
For example, the SanDisk microSD reader, (that small and beautiful, coral red and black, like the “Blade”), is prepared, so that you can open with fingernails, with a press simple (and patience).
Inside, you’ll see two “tiny squares blacks”, who have a lot of gold contacts.
These are the famous “Chips”, the technology of the XXI Century.
Well, as you suspect, in the false when opened, will see that there is no Chip!
Just a drop of epoxy resin, that coats a passive circuit (resistors, capacitors, etc.).
And is cheating at first, until it no longer works and burns your SD card.
Then… you complain about the card, in the Forum (ja, ja, ja).
_ Fourth _, but, further clarification: if we have the original of excellent quality, It is wonderful!, because with the set (microSD + reader), (this is the invention of the Pendrive), we have an “micro Pendrive the variable memory”.
_ Fifth _, in short: as you’ve probably noticed, then in the case of problems with the microSD, to formatting, etc, it best, it is the most direct connection to the computer, which is achieved with a simple adapter and the port of card the Notebook.
   3-     Write Protect: I know three cases on this subject, two that we can implement, and one, that does not depend on us.
   3.1-  The first case: is the mechanical mode (with switch).
As you can see from the photos, it is a simple switch that is to the left / up (Lock) on the SD card.
And in the same way, is the adapter for microSD, which is like an empty SD card. Also, it appears that there were anciently, UFD with mechanical switch, which is stopped making. I could never get one, only the picture (Wikipedia).
This is the best way to access public PCs without risk of malwares, because once you put the switch in Lock, it becomes read-only, and no virus can infect the SD card. Then, you put the microSD into an adapter (in Lock), and if the PC does not have a port card, you put it in USB reader card (of high quality).
   3.2-   The second case: the informatic mode (with software).
Can be done in three ways: “touching” a line Windows Registry, with gpedit.msc, or with small software (free), that does it for you without risk (1.20 WriteProtector USB, etc.).
But beware, this is only, for the PC on which you are working, not for the UFD, by it is nothing more, than an port blocker for your PC.
   3.3-   The third case: the electronic mode (due to failure the “Chip” UFD).
This, is that which we can not implement, and nor for now, undo it.
As you, saw in the Forum, there are many complaints about the problem: angers, grunts, groans, wailing, howls, and “magic” proposals…
Yet, for now the solution is very simple: return the UFD and ready.
Enjoy.
Regards, Alfred.    (Google translated).
Estimado Usuario
Así, que decidí, dedicarle a tu mensaje la tarde del Domingo, para ver si puedo aportar algo sobre este tema.
Y éste es, justamente, uno de los problemas, el que no te permite saber, si tu tarjeta funciona o no, o el que no funciona bien es el Lector.
Primero, muy sencillo: pues estamos introduciendo un nuevo dispositivo, en la “cadena de probabilidad de errores”, que no es necesario, y es peligroso para la tarjeta, si no es de muy buena calidad.
Por ejemplo, el lector SanDisk de microSD, (ese tan pequeño y hermoso, rojo coral y negro, parecido a la “Blade”), está preparado, para que lo puedas abrir con las uñas, con una simple presión (y paciencia). En su interior, verás dos “cuadraditos” negros, que tienen un montón de contactos dorados.Esos son los famosos “Chips”, la tecnología de punta del  Siglo XXI.
Bueno, como ya sospechas, en los falsos, al abrirlos, verás que ¡no hay Chip! Simplemente hay una gota de resina epoxi, que recubre un circuito pasivo (resistores, capacitores, etc.). Y que te engaña al principio, hasta que no funciona más y te quema la tarjeta SD.
Disfruta.
Saludos, Alfred.
Dear User
So I’m sure that you will return, and see this answer, and I guess “will be worth it”.
The dilemma the Cybernaut and your secure microSD
Also, I see that you name, several devices, which cause confusion, adding “more problems" yet.
First , very simple: because we are introducing a new device, in the “chain of errors probability”, which is not needed and is dangerous for the card, if it is not of very good quality.
Second , because most: (98 %) are FALSE, and bad copies of: SanDisk, Kingston and Encore (are the three brands I use, other do not know).
Third , how to differentiate the genuine the false: opening it, yes, that’s.
For example, the SanDisk microSD reader, (that small and beautiful, coral red and black, like the “Blade”), is prepared, so that you can open with fingernails, with a press simple (and patience). Inside, you’ll see two “tiny squares blacks”, who have a lot of gold contacts. These are the famous “Chips”, the technology of the XXI Century. Well, as you suspect, in the false when opened, will see that there is no Chip! Just a drop of epoxy resin, that coats a passive circuit (resistors, capacitors, etc.).
Fourth , but, further clarification: if we have the original of excellent quality, It is wonderful!, because with the set (microSD + reader), (this is the invention of the Pendrive), we have an “micro Pendrive the variable memory”.
Fifth , in short: as you’ve probably noticed, then in the case of problems with the microSD, to formatting, etc, it best, it is the most direct connection to the computer, which is achieved with a simple adapter and the port of card the Notebook.
   3.1-  The first case : is the mechanical mode (with switch).
This, is the best way to access public PCs without risk of malwares, because once you put the switch in Lock, it becomes read-only, and no virus can infect the SD card.
   3.2-  The second case : the informatic mode (with software).
Can be done in three ways: “touching” a line Windows Registry, with gpedit.msc, or with small software (free), that does it for you without risk (USB WriteProtector 1.20, etc.).
When I go to use an unknown PC, before putting the UFD, under the small software of internet (email or virtual disk), and then I lock the USB ports, which remain then as “read only”, for that the virus can not write in it.
And there, see if PC is dangerous, because when there are viruses, misleading popus, asking me to remove the “write protection”, begin to appear.
In all, the best protection is the mechanical, because there are virus packages, that block the register, for unlocking the port.
   3.3-  The third case : the electronic mode (due to failure the “Chip” UFD).
As you, saw in the Forum , there are many complaints about the problem: angers, grunts, groans, wailing, howls, and “magic” proposals…
Enjoy.
