Hi:
I own a Sansdisk 8GB clip mp3 player which I listen to with a pair of upper end shure in ear headphones.
When I turn the volume all the way to its max, the music playback just is not loud enough to suit my personal needs.
Do I need a different pair of headphones? Or is this very unusualand I should send my unit back to sandisk?
I sure am appreciative of anyones help with this issue; I have never had this problem with any of the many othercompact music players i have used over the years.
I love the player itself; it is so easy to use and so compact.
If I can just get this lack of enough volume problem under control, I will be extremely happy.
Thanks, in advance, for anyone who can help me with this isssue out in “the forum world”.
Frank
ps. feel free to contact me directly at ehbasin-9903@yahoo.com
              With my Shure SE420s, I am always in the low to mid (at most) volume range on my 8G Clip. These are very sensitive, enough to reveal a bit of background hiss. Unless you are bothered by that bit of hiss, an amp is about the last thing needed in such a setup. I’d try cross-checking with other 'phones. And of course, leave the adjustable Shure volume control in the box…
Does the volume limiting thing still exist? With 2.01.32F firmware, Language = English and FM Region = World, I can select either the “Normal” or “High” volume ranges. The latter doesn’t make a groundbreaking difference but may be handy for quiet tracks on those 600 ohm oldie cans (and yes, I am using some with my Clip).
Message Edited by keyb_gr on 06-27-2009 04:16 PM
              You could select normal or high on all the previous european firmware versions.  The volume levels were no different to the US firmware as far as I could tell (and yes I have used both).
              Make sure the headphone plug is pushed into the jack fully. No visible gap between the plug and jack. The jacks on these players are very tight when new and many have had problems when the plug is not inserted fully. It sounds dumb, but it has happened to many of us here.
              i want a program to edit the system programing to increase the volume
Message Edited by mitchfeinberg on 06-29-2009 08:57 AM
