LG Smart TV does not detect new Sandisk Cruzer Glide 64 GB
As per title
I have already formatted the key (which i bought today) to NTFS and it won’t automatically show on my LG menu when i insert it.
PC Windows 10 detects it just fine. The LG TV software is up to date. I have already tried rebooting the tv and trying different ports.
I have a few other NTFS Sandisk pendrives (Cruzer Edge 32 GB) that always worked with zero problems.
I cannot use FAT32 because some of the files are too large.
Please advise.
As always, i deleted the Sandisk security folders because i don’t care about those before formatting. However, the deletion process hung up at about half completion for a few seconds, which is unusual.
Could it be that the pendrive is now treating any of the files i put on it as secure content?
hmmmm
According to this LG link the TV does indeed support NTFS format drives. http://www.lg.com/hk_en/support/product-help/CT20136005-1436499459857-connecting-external-devices
But it also says:
“It is recommended that you use a USB Flash Drive of 32 GB or less or a USB HDD of 2 TB or less.”
and
"It is recommended that you use a USB hub or hard disk drive with a power supply.
(If the power supplied is not sufficient,  the USB storage device may not be detected properly.) "
For more information try this link http://bfy.tw/FQy1
Try formatting it as exFAT.
Yeah, i actually solved it by trying exFAT shortly after posting yesterday.
Thanks anyway for your replies.
I solved it by trying exFAT too.
Glad to hear those old responses helped you carla.
