i just bought new WD MyBook 3TB. When i connect it to my LG 47LM670S, tv writes me back, that folder or file is broken, USB couldn’t connect.
When i connect it with pc everything works fine. Disk is NTFS formated. I have another disk WD my passport and it is also NTFS formated and it works perfect with this tv.
The TV may not be able to use a drive that size. There are 2 varations formatting NTFS. Drives 2 T and under use MRB over 2 T use GPT Try posting in the video section you may find more help there sooner.
