Try a Wall charger to get it back to life… then connect to the PC. It may not have enough power to connect to the PC. Also make sure that you plug it into the USBs on the back of the computer.
Thanks for your prompt reply.
I’ve managed to connect it in MSC mode by holding the USB cable at certain angle, and can transfer songs. Unfortunately, the battery charges for a few seconds and then it stops charging. It looks to me as if there is a lose pin inside the USB connector. I’ve no wall charge but I’m sure if it’s worth buying, as I’m not sure that this will solve the problem.
What do you think? Is it dead?
BTW many thanks for you assisting constantly many members. Much appreciated.
Ron
Ron
Loose pin on which end? If its in the cable, then just try another cable, they are pretty easy to find and not too expensive. It the loose pin is in the player then contact SanDisk about a replacement because that shouldnt happen.
bought AC charger. Didn’t help. Does not charge. Power % stays at 0%. Looks like the Clip battery is good for just 1 year.
Message Edited by ron3824 on 06-04-2009 01:09 PM
My Dad’s is over a year old. It still works fine. There were some issues with people having the wire thats connected to the battery come loose. Maybe thats what happened to you.
format it
