I have bunch of Japanese songs. These have ID3tags that are in Japanese. In addition, file names for these files are also in Japanese.
I loaded these songs to the player, but no matter what I do, I am not able to get Fuze to display ID3tags in Japanese correctly. I get either Unknown, bunch of ???, or complete geblish (depending on what version of ID3tag I use).
Strangely, when there is no ID3tag on a file or ID3tags are Unknown (not read correctly), and when the file name is in Japanese, this file name is displayed correctly in Japanese.
I am using utf-8 encoding.
In addition, all songs display ID3tag info correctly on my PC.
Also, ID3tag info on same files displayed correctly on older Sandisk MP3 player (m240).
What am I doing wrong? Or is this a bug in firmware?
i had the same problem with my files that uses non-alphabet characters. the way i was able to fix this is to re-download the ID3 tags using services like gracenote or freedb. if u use Winamp, highlight on the file and right-click, select “auto-tag” on the menu that comes up. it will try to match the file characteristic with what’s on the database. if u allow it to, it will re-tag the file with the new info. u just got to be careful because there are misses! give it a try on one or two of your japanese file first and see how it works out. i have been having good luck with thai, japanese and chinese mp3 files so far.
I don’t know anything about foreign-language characters in tags, but the preferred format for ID3 tags on Sansa players is ID3v2.3 ISO-8859-1, not UTF-8. Try changing your tags to ISO and see if that helps.
I don’t think ISO-8859-1 can display Japanese characters, unfortunately…
Thanks for info. Maybe I’ll need to play around with auto tagging route.
But it would be nice to find a way to get it fixed when customizing tags.
Is there any way to find out how Winamp tags the songs and mimic it manually?
