My pc wont recognize my sansa clip. Please help me
Welcome to the forums, jarrhead76! Moved your question here to the Clip forum where it will be spotted.
µsansa
Message Edited by microsansa on 03-16-2009 06:04 PM
µsansa
First of all Go here and post your question. This is a better place for Clip questions. The answers you are looking for will be on there.
im having the same problem. did you figure anything out?
Make sure Windows Media Player 11 is intstalled you dont have to use it but you need to have it installed.
my pc wasn’t showing the player as an independent drive (all i needed, don’t use any *shudders* itunes-like utils) at first either, what helped was the following:
turn the player off
engage the hold slider (so hold is active)
hold the center button while you plug it into the usb port
profit!
This should really be in a FAQ somewhere…
- turn the player off
- engage the hold slider (so hold is active)
- hold the center button while you plug it into the usb port
- profit!
I believe it is…what you did was “force MSC mode” ![]()
