I have two questions about the Sanasa Fuze.
How can you make playlists?
Does it play Video Podcasts?
Play lists are “Easy” there is a built in playlist called the Go List to which you can add individual songs, Albums, or artist. To do this use the scroll wheel to highlight the thing you want to add and then press the select button (Round one in the center) and hold it. To do a playlist outside of the fuze I recomend useing a program like Windows media player, or media monkey, and then using that program to sync it to the fuze.’
If you can get a Video podcast with out a DRM (So not off of Itunes) you should be able to use Sansa Media Converter, to add it just like anyold video.
Okay! Thanks for your help!
