I like this cute device but recently it becomes like below (Japanese language means: database) after I cut the USB line from laptop.
Anyone has advice for me to solve this problem? I read some advice such as press the power botton together with the down botton and it shut down but when I click power botton again, it pop up with the clover screen and shows below words again.
I didn’t install rock box. Do you suggest me install it? I have a disc in package it says: Rhapsody. is it rock box?
If I install it, should I install it on laptop or sansa? Sorry I know my question is a little bit silly.
Thanks in advance!
