Getting clip to start in same place it stopped
I just received a Sansa Clip to use just for audiobooks.  I downloaded a 9 disk book with 90+ short tracks on each disk.  I had been listening to it and shutting it off directly without messing with the controls, since I discovered it would start up again at the same point–which is my objective.
Today, however, it didn’t start at the same spot.  I’m lucky that know that I was on disk 3, track 67 (as opposed to having to listen to locate my place), but it’s going to be a pain to scroll there.
Are there any tips to be certain to get it to start up at the same spot?  Is pausing before shutting it off a factor, b/c I don’t recall if I did pause it?  Any other thoughts?          (I have an iPod shuffle (2nd generation) that would do this fine b/c it doesn’t have all the features and menus the Clip does, but my gift was the Clip so I want to keep it and use it for its intended purpose.)
Thanks for the help.
