A few weeks ago my USB cable for the Fuze+ got damaged, so I couldn’t charge the player anymore. I used the player until the battery ran out. Now I got a new cable and tried to charge the player again (connecting it to two different computers, and also to a power outlet via a USB-to-power converter), but it wouldn’t charge or turn on. I tried soft reset (via the power button) and it didn’t work, but then the strangest thing did - I pressed both the play/pause button and the down part of the touch pad, and it came on and started charging! But only right until the point where I released one of the buttons (even slightly) and then it turned off again. And even this didn’t work every time.
So I’m trying to understand - is this a circuit problem and me pressing fixed it for as long as I was pressing, or is the player in the middle of some weird undocumented reset procedure?
Thanks a lot in advance.
