I have 2 Sansa Fuze (~9 month old) and they each came with a usb interface cable. I transfer recordings to and from my Fuze weekly. About 3 month ago one of the cables failed. That is: when the fuse is connected to the computer the fuse shows its connected and rechares battery ok. the computer sees the device (as drive E’: and identies it with the correct icon but when I go to the Fuze there are no directories. This seems to point to the cable since the other cable had no issues with either of my 2 units. Now the second cable has failed with the same problem. I went to BestBuy and picked up another compatible cable from another vendor. So far is working fine.
What’s up these cables?
Thanks
Richard
