My Sansa Fuze is frozen on Firmware upgrade in progress can any1 please tell me how to fix this?
Un-plug, reset & start over. (Make sure your player is in MSC mode for updating firmware)
Tried it and still doesn’t work IM very frustrated its been this way 4 two days now.
This isn’t the only resource for help, you know. Have you tried calling SanDisk Tech Support? They will either get you up & running or determine that it’s an un-fixable problem and get you set up for a replacement right then & there!
You can find all the Tech Support contact info here, depending on where you live.
This way you won’t have to B frustrated 4 two more days. ![]()
