Fuze Frozen in Upgrade mode
Whenever I turn on my Fuze, it goes to the “Firmware upgrade in progress” screen.  This started when I tried to update the software, and then it never stopped upgrading it.  Any suggestions on what I can do?  I’ve tried the reset and forcing MSC mode, neither of which have changed anything.
Did you use the automatic updater? I would suggest you do the manual update. Connect the Sansa under force MSC and reload the firmware. Click here
