I just got my sansa clip + today and after putting music on it my MP3 Player frozen while saying “Writing” on the screen… The player will not turn off nor on… what do I do to get it up in running again… anyone with info please help me…
If anyone has any info on this problem please let me know… plus now when I plug it into my computer’s USB port my computer is not recognizing the MP3 player… please give me some advice of whatnot…
He sent me a private message saying that holding the power button down solved the problem.
Letting the player intentionally discharge while it is stuck in place might not be a good idea, as the battery gauge might not be functioning properly then, and running the battery too low might damage it. If a player is new, it would be a good idea to run the battery down to around 20% or so for one or two charge cycles before charging it. The battery indicator might not be properly calibrated on a new player though, but running the battery down(not too far though) will help make the battery indicator more accurate. Initially the player might turn itself off before reaching the 20% mark indicated by the battery meter.
