I formatted my clip+ via Windows and of coarse like a fool that emptied every file in the the clip+. I downloaded the clip firmware
but every time I opened up the zip file titled clppa, it just opend another zip file titled clppa.bin. I thought it was supposed to open up some other type of files. Anyways, I put the [latter] zip file into the clip+ with no results. I have the clip plugged in and
all it says on the screen “bootloader usb mode” and when I unplug it all it says is “file not found” and “plug into usb”.
How do I get the normal files back into the Clip+ because that directory is non-existant Now. My bad.
