Clip Zip formatted, what can i do now?
Hello
I installed Rockbox on my Clip Zip and tried to uninstall it.
After it didn’t work, I formatted my clip zip with this program here.
I already tried to put only the firmware file on it, but it still doesn’t work. :frowning:
When I start my Clip Zip, still the Rockbox logo shows up and it says “Loading firmware / File not found” and then “Plug USB cable”.
I can only put Rockbox on it to work, but it doesn’t work properly. That’s why I wanted to go back only to the Sansa firmware.
What can I do now? Can anybody help me?
See this post. You’ve got the same problem and the solution is also the same.
Thank you very much! It helped! :smileyvery-happy:
