I formatted Clip+ and now its not working.I put it firmware 01.02.15 in Clip+ but nothing change.
When press the button it says; ‘‘no partition found’’
What can ı do?
I need help.
Thank you.
What can ı do?
I need help.
Thank you.
Sounds like you formatted it incorrectly. How did you do it?
I guess yes,ı did it right-click and format,just like sd cart formatting ![]()
Same problem with mine. Won’t re-format and won’t do anything. Files say they are there when connected to PC but the clip itself shows no music and then won’t re-format either.
Unless you intentionally navigate to the reserved partition, the firmware area should remain intact on the AMS Sansas. Simply right-clicking and selecting “format” should only operate on the data area (the root directory) of the device.
Does the device operate normally, meaning the Sansa logo on startup, and the main menu?
If this does work, then go to Settings > System Settings > Format > Yes, and allow the Clip+ to format itself automatically. This will erase all media from the device, allowing you to start fresh. Always have a backup of your music on your PC before clearing the device completely. If you haven’t, as they say, “there’s no time like the present.”
If the device is frozen, try resetting it via the soft reset (press and hold the power button for about 20 seconds). You can install / update your firmware from this point, as long as the device is communicating with your PC when plugged in.
Bob :smileyvery-happy:
My problem is still continue…
Any diffrent idea?
Still problem is continue…
Any different idea?
I used to with Rockbox it,and now its says this,and it is like a rockbox theme and size;
‘’ Loadind firmware
File not found ‘’
I need help.
Sorry for bad english.
up
Rockbox does not support Clip+ yet.
Try reinstalling the original firmware.
That means you have the rockbox bootloader but not Rockbox installed. Reboot into the Sandisk firmware (hold left while booting), then either uninstall the rockbox bootloader, or install Rockbox itself.
OOPS - sorry, that is true - I thought I was in the Fuze+ forum
(too many forums, not enough memory)
I was on their site yesterday, it says it does support clip plus and by other posts in various forums, it looks like it has for awhile now.
