I have a sandisk flashdrive 4gb that I use to bring work files home from the office to work on at home and then transfer any new data to the hard drive at the office. Last night — all my files were nowhere to be found on my flash drive but when I use properties it says 1.62 gb of a total of 3.73 memory has been used which makes me think the files are still there. Can anyone help me — I am not very computer literate.
Well Dave, I suspect the flash drive3 was not Safely Removed and as such the Fale Allocation Table is screwed up. From a Command prompt window try running CHKDSK on the drive. Hopefully that will resolve the problem for you.
I am sorry to be so stupid ---- how do I do that. I went to RUN and did chkdsk - thinking it would ask if I wanted the C drive or the F drive (where the scandisk is showing) but it just checked my C drive
If a drive is not specified CHKDSK runs for the drive that the command is executed from. The default drive for the Command Prompt is Windows’ C: drive.
To run for the flashdrive either 1. switch the Command Prompt to the flashdrive’s drive letter or 2. enter the flashdrive’s drive letter to the CHKDSK command.
Assuming the flashdrive has drive letter F:
1.
C:\Users\Ed>F:
F:\>CHKDSK
C:\Users\Ed>CHKDSK F:
OK?
Also to find help for any Command Prompt command enter the command’s name followed by /?.
