My 4FG USB flash drive shows RAW and all stored 2GB of videos cannot be opened or accessed before formatting. Do you have any idea to fix this? Is it still possible for me to view these stored videos again? Any help would be very appreciated. Please, help me!
Try opening a Command Prompt and entering CHKDSK followed by the drive letter of the flash drive. Something like:
C:\Users\Harold> CHKDSK f:
Try just a quick format using Windows too and see if that will fix it for you. Hopefully, it does. ![]()
Formatting may fix the RAW problem but OP may loose their videos as a result.
