Hi there. I use the clip on a linux box and I am curious if the file format of the clip is defined anywhere. Specifically, I’d like to get access to the information that the sansa knows when I select a podcast (i.e. start where you left off), or even better, if a file was ever listened to. I would like to use that information to remove played files (podcasts in my case) from the player.
It’s fat32 and Linux has no problem with the fat file system. I don’t use Linux although I did run a dual boot system for a while. I have a Puppy Slacko bootable flash drive that I can use on systems having windows boot or virus problems.
I would suggest formatting the clip from the settings menu rather than from Linux just to be safe. You will of course need to set the clip to MSC mode.
Please don’t dredge up a 5-year old thread. Start a new one instead and pose your question or issue in a complete and concise way to where people will know what exactly you are looking for.
