hi everyone
i need some help…
i have recently bought the wireless stick 128 GB
seems great…
i use it from my android phone (galaxy note 4, android 6.0.1 rooted)
i have installed the connect app from the store
connexion seems ok via the app and a little bit erratic when usig es explorer app
i began to transfer files from my phone… one or two videos… transfer ok…
was very happy!!
but, rapidly, some files failed to transfer from my phone to the stick… failed operation with es explorer, and with the connect app…
i tried also to transfer some photos from my phone to the stick… via the connect app
some photo do transfer correctly ant others absolutely not! don’t know why???
i haven’t tried much type of files yet but i don’t understand why simple transfer does not always succeed correctly
videos files do not have excessive size (700 MB) and photos had nothing particular
tried to put 4.1 firmware update from the pc
ejected correctly
don’know if it worked but update file was not at the root of the stick when i reconnected it
tried again after firmware update
same files failed again
stick is correctly charged
someone has an idea??
should i ask for exchange??
thx for your help
