My e280 no longer plays music. When I select a song, it works just fine but then it doesn’t play anything and the time remains at 0:00. I can pause it and play again and the pause/play indicator works but otherwise nothing. The battery also shows as being low even though it is full. Radio plays just fine.
The problem started when I unplugged it from the computer after getting new music. The screen remained on the “connected” view until I turned it off. When I turned it back on, it did the “refresh database” and then would not play. The next few times I turned in off and back on it refreshed the database again, and then stopped and started showing the low battery. I’ve reset it and formatted it but to no avail.
Do you have any suggestions or is it beyond hope?
