E200 Basic Information
**Sansa e200
Latest Firmware: **
v1; 01.02.24a  , v2; 03.01.16a
General
  • Sansa e200: Users Guide
  • Product Number: SDMX4-8192-A70
  • Product type: Flash Player
  • Dimensions: 1.7" (width) x 3.5" (length) x .5" (height)
  • Weight: 2.6 oz
  • Key Features: Photo viewer, Video player, Audio player
  • PC interface(s) supported: Hi-Speed USB
  • Flash memory installed: 2, 4, or 8GB integrated
  • Software included: Sansa Media Converter
Display
  • Display Type: Color LCD 1.8"
Memory card/ Storage
  • Flash Memory Cards Supported: microSD & microSDHC*
Digital Player / Recorder
  • Digital audio standards: MP3, WMA, Audible**, Protected WMA (DRM)
Video
  • Video Playback Formats: .mov
Battery
  • Battery: Rechargeable
  • Battery Enclosure Type: internal / replaceable
  • Battery Life Details: lithium battery for 15 hours of audio or 5 hours of video*
Audio System
  • Sound output mode: Stereo
Cable(s) / Peripheral(s)
  • Cable(s) included: 1x 30 pin propietary to USB cable
Connections
  • Connector type:  1x Headphones Mini-phone stereo 3.5 mm, 1x USB
Microphone
  • Microphone type: Built-in
Headphones
  • Headphones type: Binaural Sound
  • Output mode: Stereo
  • Connectivity Technology: Wired
System Requirements
  • Peripheral / Interface devices: CD-ROM, USB port
  • Minimum Operating system: Microsoft Windows Vista, Microsoft Windows XP SP2
This device comes in 2 versions (how do I tell the difference?). Version 1 does NOT support SDHC natively, Version 2 does support SDHC.
Only Version 2 of these devices support audible.com content.
Music: Based on continuous playback at 128 kbps MP3; battery life and performance may vary depending upon usage and settings; battery is user replaceable.
**** Video: Based on continuous playback at QVGA 512kbps H.264
Message Edited by MrSmileyFace on 04-14-2008 08:14 AM
Message Edited by microsansa on 08-09-2009 11:20 AM
Message Edited by microsansa on 01-31-2010 10:00 AM
Moved to e200 sub forum
Please update the information about the actual firmware version,
what is the recent version for e2XXv2?
Is it 03.02.05H or 03.02.05I (Apr-2008)?
You mention the audio file formats, but you write
nothing about the proper mp3- or wma-standards, -
for example, are there restrictions for dynamic bit-rates?
Kind regards,
ellocco
Kind regards,
ellocco
As of today, April 11, 2008, the latest firmware for the e200 V2 player is 03.01.16. It will have a suffix for the region. The 03.02.05H firmware you are asking about is not for the e200 but the c200 player.
To find info. on the file types, do a search in this forum. Search by “ID3”, “MP3”, “WMA”, etc. You will find a lot of information and quite a bit of personal preferences for bitrates and other details. There is a lot of information, more than will fit into the brief “Basic Information” positng. Maybe that is why it is limited to just basic information.
Hi Professor,
thank you for the information. I have problems with
drop outs, after upgrading the firmware from 3.01.14E
to 3.01.16E the situation is now quite good, but there
are still drop outs.
I wonder if the drop outs have something to do with
the variable bit rate.
What do you think? Have your heard about that problem
of drop outs?
Kind regards,
ellocco
Message Edited by ellocco on 04-12-2008 04:36 PM
Hi Mr Moose,
where did you get your information about the latest firmware version,
could it be that 3.01.18E is the latest? (state: Apr.2008)
See:
http://www.anythingbutipod.com/forum/showthread.php?t=13521
Kind regards,
Stefan
@ellocco wrote:
Hi Mr Moose,
See:
Kind regards,
Stefan
There is another sticky in the begining of this forum that lists the latest firmware, you can check the Sandisk website, or you can check using the Sansa Firmware Updater. During release of new firmware one or the other of these sites may lag by a day or two. Eventually all three sites are updated to be in agreement.
The site in your link gives firmware for the V1 player, not the V2.
Thank you for clarification!
Regards, ellocco
Updated to show changes.
Will be deleting all above post in order to keep this thread clean.
Please also update the information about
the bit-rates, which bit-rates are supported
and are there restrictions for dynamic bit-rates.
Regards,
Stefan
ellocco-
Please open a new thread instead of building on this one, so Mr. Smiley Face can clean it up.
Bob  :wink:
Message Edited by neutron_bob on 04-14-2008 11:57 AM
I’ve posted this before, but there is no response.
Two suggestions:
1.)
Please use international units (SI-units) for lenght dimensions and weight,
this forum here seems to be international.
2.)
Tell something about bit-rates and variable bit-rates for sound files.
Regards,
Stefan
I will be sure to update the measurements to show both units of measurement.
In regarsd to bit-rates, the player supports bitrates at 128kbps and it is at this setting testing is done. If a user wants to use higher/lower bitrates, it is his/her discretion to do so.
If you want to get more specific, feel free to start a seperate thread to see what some of the users are currently using as bitrates.
Hello Mr Smiley Face,
you are kidding!
I’m interested what the official
bit-rates are.
128 kbit/s is really poor for mp3.
I have drop out problems and before
shipping the equipment back to the factory,
I want to know what the official bit-rates
are.
Especially, if I encode with variable
bit-rates.
Is this the official version, that sansa
products are not compatible to variable
bit rates?
I have copied your response and perhaps
I post it in other forums, if this is the
official information for bit-rates on the
sansa players.
Kind regards,
ellocco
The e200 will support any bitrates from 64-320kbps; both wma or mp3.
I personally know that variable bitrates will work fine, but there is no “official” documentation on this. The only mention of bitrates that SanDisk has provided is the quality of tested mp3’s.
So if I have drop out problems,
you suggest encoding with
fixed bit-rates and see, if the
problem is still there.
So the official version is: Sansa e200v2
is not tested with variable bit-rates,
if it works, the customer can be happy.
That is really interesting information!
So, here is my request:
Include variable bit-rates into the next
firmware and publish the variable bit-rates
that are supported.
Kind regards,
ellocco
If you would like to make a request, please do so in the “feature suggestions” thread. I would imagine if it got enough backing from the general public, it is more likely to happen.
I do not accept firmware request, as I am not involved with that process
P.S
This post and all its replies are going to be deleted shortly. Please be sure to create a new thread if a topic needs to be brought up.
If you would like to make a request, please do so in the "feature suggestions" thread. I would imagine if it got enough backing from the general public, it is more likely to happen.
I do not accept firmware request, as I am not involved with that process.
P.S
So please update the basic information
for sansa e200v2, the weight is not so
important in comparison  to the information
what bit-rates the player supports.
Regards,
Stefan
Great guide. I just noticed one thing though. You messed up on the *'s. You put ** twice, so where the second ** (or right here: Battery Life Details: lithium battery for 15 hours of audio**) should be *** instead.
