I have a new 16gb Cruzer with secure access. Used it many times and to back up a pc that I sent out for repair. Plugged it into a new laptop and now cannot access the vault. Cannot find the - runsecureaccess_win.exe file that I think I need. Am I right and if so, where can I get that file without reformatting the Cruzer? I need the data on it.
Yes, I got the same problem too. Who can help for it… urgent
Seems like you’re trying to access the drive on a Windows7 puter.
To access the files, use your drive in a non Windows7 puter. BackUp the files to another plain flash drive.
Reformat drive.
Then update your Flash Drive with the new software to allow you to access the files on a Windows7 puter.
If you want to use SecureAccess, then reinstall it.
http://kb.sandisk.com/app/answers/detail/a_id/2399
u3 update for Windows7
http://kb.sandisk.com/app/answers/detail/a_id/240/kw/u3/r_id/101834/sno/0
BackUp Software
http://kb.sandisk.com/app/answers/detail/a_id/5206/kw/sandisk%20back%20up/r_id/101834
I cannot open my SanDisk USB flash drive. I cannot find the RunSecureAccess_Win.exe file on my Toshiba laptop Windows 7 computer.
" I cannot find the RunSecureAccess_Win.exe file on my Toshiba laptop Windows 7 computer."
I doesn’t exist on your computer, it exists on the USB flash drive.
If you cannot open your USB flash drive I suspect there is a security setting on your pc that’s restricting access to USB drives.
