there is a secure access post stickied at the top of this board. redownload it and reinstall it. you may want to format the drive first just to clean everything up.Â
Hello, I also accidentally formatted my Sandisk Cruzer Blade GB (SDCZ50-008G) , thus deleting the files including the factory installed software/s. Good thing, i had the files saved on my computer. Please help how could i recover the factory installed software.Â
I am having the same problem as the above poster, and upon downloading and running the program mentioned, I keep getting an error asking to run the program from an external device.
“My computer” wont show the device, and I have gone through the driv updating/drive letter change options mentioned on the website.
Any other ideas who I may be able to use this flash drive again?
Hello there,
I have a doubt. If I safeguard my data into sandisk secure access and afterwards anybody accidentally delete my .exe file and application and then am I able to get my data back ?
Your response will be appreciated
Thanks
hmmm Interesting question. I would say probably not. But if the vault is deleted and NOTHING is written to the drive it might be possible to recover the vault. Reinstalling the .exe should not be a problem if the vault is recovered.
