well i went to delete some songs off my sansa clip on the My Computer\Sansa Clip 2GB, and then i went over to the media player and it shows that the songs i just deleted are still on my device… so i tried deleting it via media player… and it tells me:
“windows media player can not delete a file from the device.”
and if i check the player it does indeed tell me there are no songs on the player… but at the same time if i check the memory, it shows that something is taking up space.
i tried installing the newest update, version 01.01.20A… still the same thing…
i even tried following this advice, which i got from another post on this forum:
“To delete the database in a v2 put it in MSC mode, look in the root directory (just the driveletter) and delete mtable.sys.”
still nothing…
how can i resolve this problem?
thank you for your help.
