Hi Alan,
Dear member of SanDisk Community, welcome.
Remember that, there are two softwares, one for Windows and one for Mac.
Compatibility:
SanDisk SecureAccess software is supported by Windows XP, Windows Vista, Windows 7, Windows 8, and Mac OS 10.5 and up.
Use with a Mac requires other software download.
And SanDisk SecureAccess Software you must install in the UFD.
The latest version of SanDiskSecureAccessV2, you can download (free) from here:
http://kb.sandisk.com/app/answers/detail/a_id/2399
http://kb.sandisk.com/app/answers/detail/a_id/2413
1- Download on the UFD, to SanDiskSecureAccessV2_win, (if you have PC).
Beware 1: If you figure thus: SanDiskSecureAccessV2_win .exe , go Tools/Folder Options/tab/View/ and tick: hide file extensions, by the way, you notice, that are also branded the choices: hide files protected, and do not show hidden files and folders.
2- Then, you install the program, password, etc. And you will have two files:
2.1- SanDiskSecureAccessV2_ win , (the application).
2.2- SanDiskSecureAccess Vault , (which is the folder that contains the encrypted files).
2.3- If you lose or delete to SanDiskSecureAccessV2_win (2.1), there is no problem, as other download, and ready.
2.4- But if you lose or delete a SanDiskSecureAccess Vault (2.2), missed all content.
2.5- If, you can change the name, the application (2.1).
2.6- Do not you can change the name, the folder/Vault (2.2), because the name is generated by the application (2.1), and if you change it, the application will not open, and will generate a new Vault.
2.7- If, you can move on, too, to the application (2.1), a any folder.
2.8- You can not move the folder/Vault (2.2). You should leave it in the root of the UFD, because that is where the going “find” the application (2.1).
2.9- There is an option (in the toolbar My Vault), _ which generates a Backup _ (for SandiskSecureAccess Vault), to your PC.
Beware 2: Always make, backup content, copy the Vault, clone the UFD, etc., and save everything in “safe place”.
Enjoy!
Regards, Alfred. (Google translated)
Hola Alan ,
Estimado miembro de la Comunidad SanDisk , bienvenido.
Recuerda que hay dos softwares, uno para PC y uno para Mac.
Compatibilidad:
SanDisk SecureAccess softwarees es soportado por Windows XP, Windows Vista, Windows 7, Windows 8, and Mac OS 10.5 and up.
El uso en una Mac requiere descargar otro software.
Y que SanDisk SecureAccess Software, debe ser instalado en la UFD.
Está la última versión, de SanDiskSecureAccessV2, que puedes descargar (free) de acá:
1- Descargar en la UFD, a SanDiskSecureAccessV2_ win , (si tienes PC).
Cuidado 1: Si te figura así: SanDiskSecureAccessV2_win .exe , ir a Herramientas/Opciones de carpeta/pestaña/Ver/ y tildar: ocultar extenciones de archivo, de paso, te fijas que también estén tildadas, las opciones: ocultar archivos protegidos del sistema, y no mostrar archivos y carpetas ocultas.
2- Entonces, instalas el programa, contraseña, etc. Y tendrás dos archivos:
2.1- SanDiskSecureAccessV2 _win , (que es la aplicación).
2.2- SanDiskSecureAccess Vault , (que es la carpeta que contiene los archivos encriptados).
2.3- Si pierdes o borras, a SanDiskSecureAccessV2_win (2.1), no hay problema, pues descargas otro, y listo.
2.4- Pero si pierdes o borras a SanDiskSecureAccess Vault (2.2), perdiste todo el contenido.
2.5- Si, le puedes cambiar el nombre, a la aplicación (2.1).
2.6- No le puedes cambiar el nombre, a la carpeta/Vault (2.2), porque el nombre, es generado por la aplicación (2.1), y si lo cambias, la aplicación (2.1), no lo va a abrir, y va a generar otro Vault nuevo.
2.7- Si, puedes cambiar de lugar, también, a la aplicación (2.1), a cualquier carpeta.
2.8- No puedes cambiar de lugar, a la carpeta/Vault (2.2). Debes dejarla en la raíz de la UFD, porque ahí es, dónde la va a ir “a buscar”, la aplicación (2.1).
2.9- Hay una opción (en la barra de herramientas de My Vault), _ que genera un Backup _ (para SanDiskSecureAccess Vault), a su PC.
Cuidado 2: Hacer siempre, backup del contenido, copiar el Vault, clonar a la UFD, etc., y guardar todo, en “lugar seguro”.
¡Disfruta!
Saludos, Alfred.
