I just installed SecureAccess on the Mac and am running it on my Sandisk Ultra 32GB drive. I got my files into the vault but can’t figure out how to get them out! I can’t use the Save Files to… option (“unable to save into folder”) and if I open it and try to save it directly from whatever app is running, that doesn’t work either. I need to be able to open a file, save it on the computer or on the USB drive unencrypted while I work on it, then put it back in the vault. Is that not possible?
Remember that, there are two softwares, one for Windows and one for Mac.
And SanDisk SecureAccess Software you must install in the UFD.
Compatibility: SanDisk SecureAccess software is supported by Windows XP, Windows Vista, Windows 7, Windows 8, and Mac OS 10.5 and up.Use with a Mac requires other software download.
The latest version of SanDiskSecureAccessV2, you can download (free) from here:
I installed the Mac software on the thumb drive. I assume that is what you mean by the UFD. I still can’t figure out how to get a file out of the vault.
If, on the UFD (pendrive orUnit F__lash Drive), you should have two files:
1- SanDiskSecureAccessV2_ mac , (the application). 2- SanDiskSecureAccess Vault(which is the folder that contains the encrypted files).
3- If you lose or delete to SanDiskSecureAccessV2_mac (1), there is no problem, as other download, and ready. 4-But if you lose or delete a SanDiskSecureAccess Vault (2), missed all content. 5- If, you can change the name, the application (1). 6-Do not you can change the name, the folder/Vault (2), because the name is generated by the application (1), and if you change it, the application will not open, and will generatea new Vault. 7- If, you can move on, too, to the application (1), a any folder. 8-You can notmove the folder/Vault (2). You should leave it in the root of the UFD, because that is where the going “find” the application (1).
