Coping music from Sansa Clip
I was wondering if it is possible to copy music from the clip to my computer? I lost all my songs off my computer.
Yes, you can drag and drop in MSC mode or MTP mode, or you can synchronize using Windows Media Player.  Remember that Microsoft designed a quirky barrier between the two modes: if you don’t see your music (connect the Clip, and have a look at the contents by Windows Explorer (My Computer), you are in the alternate mode.
Files loaded in MSC or MTP mode are only visible while in the same mode.
Bob  :smileyvery-happy:
Message Edited by neutron_bob on 08-09-2008 07:04 AM
