Convert button doesn't work
My first post here. So, I have Sansa Fuse 8GB. I use Sansa Media Converter all the time and it always works. But today I wanted to convert some videos (they are all AVI and they are a bit more then 1 GB when I have 5 GB free) so I added them in the program, but I could’nt convert them. The convert button isn’t glowing and I can’t click it. I have Windows Media Player 10 and Quick Time too. I don’t know why it doesn’t work. I hope someone can help.
Thank you.
Thank you.
If you can’t get SMC to do the job you might be interested to try alternatives: check my tutorial on How to create video for the Sansa Fuze without using SMC.
Is the Fuze plugged into the computer? The Convert button stays greyed out until it sees the player.
 It’s not the solution for your problem, but until you find it, you could try to convert those videos using video4fuze
I think it’s plugged in. There is an exclamation mark under Information Device in Sansa Converter… I don’t know what that means. Still, it shows how much space is left so I think it’s plugged in.
Thanks ssorgatem that helps a lot. It works just like I want it to.
Thank you.
Oh really? Then I suppose that identical post by you in the Frequently Asked Questions and User Suggested Stickies board with a time-stamp of 9/05/2009 12:03 PM is a figment of my imagination?
This post is stamped 9/05/2009 12:31 PM. More or less a half-hour later, unless you travel via the Time Tunnel.
The moral of the story? It’s OK to copy & paste from one board to another; in fact ConversionBox suggested this would be a more appropriate venue . . . however, you should probably re-read and edit the post where necessary. :wink:
