I turned my Sansa e260 on And it said “Battery to low system shutdown” I connected it to my computer (to charge it I presumed) and it connected, but didnt start charging. It showed a full charge. So I went back and forth with this a few times before I cam eto the boards.
Tried to update the firmware, but I think i’m stuck somewhere between .15-.18 But trouble is I can’t turn the player on unless it’s hooked up to the computer (So i can’t do anything IN the player itself) but I can put it into recovery mode while it’s hooked up to my computer.
I’m sure this has been asked before, but I really can’t find anything.
Any help at all would really be appreciated. I’m going crazy at work with nothing to listen to…
I’m having a similar problem. Does “reseating the battery” mean take the battery out and put it back in? I’ve tried that and it still won’t charge. I know it’s not a bad battery, because the battery will charge in my other E250R. Any ideas? Thanks!
I’m actually having the same problem. Since I had a mainboard linked problems on my pc the charging symbol doesn’t appear when I connect the player. The player doesn´t turn on automatically either, when I connect it to the PC. Once connected to the PC and turned on by hand, I know that the battery actually gets charged, but as soon as i disconnect the player from the computer it turns itself automatically off. When I try to turn it on again it only says "Battery Status too low System shutdown.
Does anybody know how to fix that problem. I 've already reseated the battery and installed the latest firmware. Thanks
