Gday
I thought Id share my experience of how I fixed the problem of my computer not detecting my Sansa Fuze, because it seems like alot of people are having the same problem.
I received my Fuze in the post today. I bought it new over ebay from a dealer in Sydney and its wicked… but I was shattered to discover that when I plugged it into my PC I was unable to access it, or see an icon anywhere. When I first plugged it into my PC I got a message saying ‘new hardware found… installing driver. Then I got a message saying ‘this device may not be working properly’.
I searched the forums here and did all the things people suggested:
I knew that my system met the minimum requirements and that I was running Windows Media Player 11. I tried soft resetting (hold off button for 10 secs), formatting, resetting to factory standards, I rebooted my PC several times etc… none of this worked.
Next I looked in the Device Manager and this is where I was able to fix the problem. (Right click My Computer > properties > Hardware’ tab > click ‘Device Manager’)
I noticed that when my Fuze was connected to the PC there was an entry under ‘Universal Serial Bus Controllers’ in Device Manager which said ‘Mass Storage Device’ and it had an exclamation mark next to it. When I right clicked, it said… ‘this device is not working properly’. (This was my troubled Fuze obviously and for what ever reason the drivers that windows had installed for it were not working properly).
So I Right clicked on the Mass Storage Device icon and selected ‘uninstall’… then OK’ed it.
Next I shut down my PC and disconnected the Fuze > Reboot PC with Fuze disconnected.
Turn Fuze on (Don’t connect it yet). Go into the settings > System Settings > USB Mode > change from default ‘Auto’ to second option ‘MTP’
Then connect your Fuze to the PC.
When I did this my PC detected the Fuze and was able to install a correct driver for it…
Go back into the Fuze Settings and change USB Mode back to ‘Auto’.
Having done this my PC recognizes the Fuze everytime and it shows up as a portable device in Windows Media Player… However Im still having trouble getting Winamp to behave properly with it!
That went a long way to fixing the issue for me… hopefully it will work for others too.
Cheers
Message Edited by Lukas101 on 07-30-2008 03:37 AM
