I have a Clip+ and a Fuze which I love and have had no problems with. My wife is an avid Ipod fan but wanted a small player for the gym. Persuaded her to get a Clip Zip as she can keep her itunes library and put them on the Zip.
Got a 4gig player with a 4gig Sandisk card. She loaded her itunes on the zip and all worked fine. When this was full loaded the rest onto the card. At which point the player keeps crashing about 3/4’s through ‘refreshing’. Battery drains in no time. Won’t turn on when charged but if I reset it goes through the ‘refreshing’ mode and then turns itself off. if I take the card out it works fine but won’t play when I insert it. Put in the card from my clip+ and it works fine. Have updated the software to the latest version but still no joy.
Apologies I have looked at various posts which mention the same kind of problem but have had no joy so far with a solution.
I got the Zip so that she could keep her itunes library but sadly at the moment we are not having much luck.
I’d welcome any advice
