My 4gb ClipZip has stopped reading SD cards. It was able to do this fine until a few days ago when I used a travel charger to charge the device.
The ClipZip plays music from the internal memory okay, but it now freezes on the “refreshing your media” screen when I insert an SD card. I hope the charger has not damaged the device. I have tried resetting and restoring the settings several times.
Thanks for your advice. The player can’t access ANY of my SD cards, though. My two Sansa Clip+ players and my Sansa Fuze can access all of my SD cards with no difficulty so I am a bit concerned about my ClipZip, especially as it worked fine for the first three months or so.
I should also say that I recently had to install a new hard drive in my laptop PC as the old one was worn out. Therefore, I had to start from scratch and reload all my system recovery discs.
I connected my ClipZip to my “new” laptop recently, too. Could this have affected my ClipZip? Is there anything I can do to fix this problem? Would reinstalling the pkayer’s firmware help?
Yes! Removing content and reinstalling firmware has helped a lot. The player can now read and play SD card content, although it does tend to take longer than before to access the card and to switch on. Also, the firmware version is now 01.01.20P rather than 01.01.20"x".
