My Clip (2GB Euro model without radio) has started being very erratic in performance. Startup is slow compared to instaneous before and it refreshes the database each time it starts up. I’ve tried resetting a few times but not done anything with the firmware yet. Any other suggestions?
3. Press-n-hold the center button & connect it to PC & keep holding until the device shows “Connected”
4. Double click on “My Computer” & see if you can see the device as a removable disk (i.e. drive F, G, etc…)
5. Now, once it’s connect as a removable disk (i.e. drive G), then go into DOS mode on your windows by pressing Win + R or press on “Start > Run” and then type in cmd to go into DOS mode. Once, you have open up the DOS windows,
If you want to check the integrity of the device, type this:
chkdsk g: /f
If you want to format your device to clean it up, please type this in to format the device completely:
format g: /fs:fat /a:32k /y
if your drive is different than g, just change it. Once you’ve finished the formatting, unplug from PC & see if it will fix your problem. Also suggest upgrade to latest fw
If you want to know more about dos, type in help /? or chkdsk /? or format /?
