My Clip player won’t work at all if I disconnect it from its USB connection/my computer. When it’s plugged in it works fine (I can put files on it), as soon as I disconnect it the player goes completely dead. I’ve tried to reset it, etc. with no luck. Is this a battery issue? It’s at 100% power right now, I charged it for 3 hours, etc. I don’t know if it’s defective or if this can be fixed. Thanks in advance for your help.
