I’ve written about this problem before but thought I had it figured out that the reason the card showed
the files as MSC when I had the player on Auto Detect was that the card that did this was PNY
brand and the card that read correctly was San Disk brand.
Not so. Bought a new card San Disk SD 2G yesterday and put it into a fairly new Clip+. It shows these categories:
Audiobooks, MSC, and Podcasts. Is it just not possible to keep the same USB setting and move
the card from one player to another. Why the MSC setting which I haven’t seen on my other two
cards? Do I need to format? What can I do so that files can be seen on each of my devices?
My clip+ devices have all firmware that exists.
If none of this is possible then I’m done with memory cards.
Donna in AR
