No. Settings/Format–> “Format Complete” , music is empty but when i connect to my computer the mp3 files not delete, disconect to pc and turn onand appears mp3s again conclusion:not format, same problems first post
some mp3 files are 0bytes, and when i turn on clip freeze 40 seconds
And you can’t reformat the Clip from your computer either, right?
Can you connect to your computer, right-click on the Clip drive, and run a checkdisk on the Clip drive (under Properties, I believe)? Something is goofy, here …
Will it work now, after using Partition Wizard? It sounds like there is a disk surface error–the only thing I can think is to try other partitioning/formatting tools, to mark off the errors and format the rest.
Sorry, I can’t think of anything else. Perhaps contact SanDisk Customer Service (or, if you are with the player’s warranty period, try returning the player for a new one). Perhaps others here will have other advice.
BUT! Player work with old rockbox and old original firmware (work with freezes, errrors, etc.)! But I don’t delete music from it. Disk check don’t finish with unknown error. Partition wizard 7 output corrupt disk. No warrantly.
Original firmware don’t install (I tried boot with pushed left key - nothing). Rockbox don’t uninstall! Manually or automatic - that’s all the same as a result - rockbox don’t delete. My clip+ - forever rockboxed!
To uninstall rockbox you have to boot into the Sandisk firmware. You’ll have to figure out how to fix it before you can uninstall. Which is probably a good idea, since if you could remove rockbox without fixing the Sandisk firmware your player would be bricked.
