Sorry if this has been mentioned anywhere before… I searched but didn’t find anything.
I can’t copy to my clip+. Even trying to copy 1 file from the desktop to the root folder
results in a “Cannot copy xxxx path too deep” message.
Since this started up I deleted the 500MB of files off the Clip and reformatted so it’s empty.
Totally baffled… I am running Windows XP SP3.
Any thoughts would be appreciated.
Thanks for the reply.
Unfortunately I have no way at present of updating the firmware. For obvious reasons I can’t
download the zip file with the clppa.bin and copy it to the root folder…
because I can’t copy anything to the Clip!
Plus, trying to use the Sansa Updater will not work. I run the file and nothing happens. I’m
connected to the Internet and my Clip is connected to the PC, but it doesn’t run…doesn’t do anything.
I’m already on MSC mode.
I have to think this is a Windows thing…constant security updates and other sundry rubbish it keeps
advising me to update. I was having no trouble a week ago then the Security Centre in XP came up
with about 30 updates and it’s gone doolally from about 2 days ago.
Thanks once more for your input, I appreciate you taking the time.
OK… I uninstalled the Clip driver. Detached the clip, re-attached it. Windows did indeed
generate a new driver and after a couple of seconds the Clip showed up in the “My Computer”
window and the root folder opened up…followed by a Windows message window.
I wasn’t sure if it was acceptable to post a link to an image, so here’s what it said…
The window title( the blue bar at the top) says “Windows - No Disk”
The main body of the message…to the right of a **bleep** big red x…was
“Exception Processing Message c0000013 Parameters 75b6bf7c 4 75b6bf7c 75b6bf7c”
Under that, the usual three buttons… Cancel-Try Again-Continue
I clicked Try Again and Continue 4 or 5 times to no avail…then I had to click Cancel about
a dozen times to get rid of that message window. Whatever the hell that meant, XP didn’t
seem to like it much!
Soooo… I’m back to square one. I think maybe it’s time to do a clean install of XP, I really
can’t think of anything else to do…
@miikerman wrote:
I have read techies out there say that to keep their PCs running in prime order, they reinstall Windows every year. Sigh.
I think those people have way too much time on their hands.
Hmm, so you suspect XP has gone wobbly, hold off from a full reinstall for now and try the following… worked for me
Download this fully validated, anti-trojan freeware http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button and also the file/program remover Revo Uninstaller Pro http://www.revouninstaller.com/revo_uninstaller_free_download.htm (30 day free trial - no credit card needed).
I use these pieces of software often (bought revo upgrade last mth), both are spam-free, trojan-free & reliable pieces of kit that do exactly what they says on the tin!
Install both and start malwarebytes to scan for any nasties, if any are flagged up after clicking ‘Show Results’, then hold off deleting them in Malwarebytes and use Revo Uninstaller to remove them instead - it has the option to deep clean your registry of any ■■■■ you may have inadvertently picked up and does a much better job imo. ie use Malwarebytes 4 detection
Depending on whether you choose quick scan or full scan in malwarebytes, the entire process from installer download to end of scan in revo uninstaller should take around 30 mins.
the Clip+ can be very tempermental sometimes when trying to copy files, so if you manage to get into the root folder, delete the existing clppa.bin folder and replace it with version clipplus01.02.16 http://kb.sandisk.com/app/answers/detail/a_id/300 or if you fancy doing a manual install follow http://www.rockbox.org/wiki/SansaAMS#Installation click first wiki link only, then follow instructions given by Sansa forum poster.
Do you have Rockbox installed? if no, then consider the following…
I installed the latest version of Rockbox (reformats the OS of the Clip+ and you end up with an ocean full of oomph - in the same way as having your ecu chipped) and it connects right through my entire (complex) folder structure every time. Standard Sansa firmware/menu options do not come anywhere near the functionality of Rockbox
Hope you find this useful
@miikerman wrote:
Glad you got the player up and running! And this is a reason why I value my Norton Internet Security program.
Ady_P_UK is not the OP with the problem. I believe he was offering a suggestion and/or potential solution to HumptyNumpty’s path issue.
@miikerman wrote:
But even then: today I upgraded to the latest version a well-respected media player on my computer. And without ANY warning or option otherwise, the media player, automatically and without any notice (but I noted what was happening as files were being installed) installed a 3rd-party search engine into each of my browsers and swiched my default search engine under each browser to that. Needless-to-say, I was ticked (although it was easy enough to uninstall and reverse the default).
Bet I can guess what POS (piece of [ahem] “software”) THAT was . . .
Not iTunes, if that’s what you’re thinking:stuck_out_tongue:…when the update notices come for that, you can clearly select what you want installed and what not to install.
Nope, that’s not what I was thinking.
for that error message “path too deep”, I would suggest to use the Long Path Tool… I used it when I encountered the same error message.
Hope this helps…
Hello again and apologies to those who have given their time and effort on this and had no
response till now!. I got sent away on a training course and had no internet access.
Sooo… now I’m back and…long story told short, I attached my clip to the PC basically thinking
“one more attempt before I investigate all the options these guys have suggested”… and yep,
I was able to copy to the Clip straight off! DOHHH! I have no idea what’s gotten the situation
back to normal. Maybe my PC just needed a rest! For the moment I’m going with it.
Thanks for all the suggestions and links. I’ll be keeping them handy just in case it all goes wonky
again. Actually I now have a problem with a MicroSD card I installed…but that needs a new topic.
Anyways, thanks again…y’all are heroes!
Long Path Tool helped me in this situation. http://PathTooDeep.com
<spam removed>
We’ve already had 2 recommendations for this software in this thread. The fact that _ nobody _ mentioned that this “tool” is available on a free trial basis, and then you have to pay for it simply amounts to spamming, something not appreciated nor allowed here.
Even if unintentional, 3 links to somethng in the same thread is 2 too many.
I have been having the same pesky problem and no matter how many times I restart my computer, well, it doesn’t really work. I am not a techy person so I’d like to check if there’s a quicker way to solving this. Has any1 heard of a Long Path Tool from pathtoodeep(dot)com. Not sure if I can post links but read their FAQ and the site seems legit… Searched for reviews online and all of the users had positive feedback. Any ideas?
Is this a legitimate post or a pathetically weak attempt at spamming? If you genuinely have a problem and want to try that software go right ahead. But the link to it has already been posted in this thread 3 times! Please do not post it again.
I have reported all instances of this link as spam due to the fact that it is only available free for a limited time. Then one has to pay for it. By not mentioning this fact, anyone who posts a link to it and doesn’t disclose that fact is spamming, pure and simple.
Additionally, I have never heard of a legitimate need for whatever this long path tool does with any Sansa player. So it’s benefits are a mystery to me and I suspect it’s simply a ‘tool’ to facilitate or introduce malware or some other unwanted code onto host computers. In which case, linking to it would also be derelict, against Forum Rules & Guidelines and justification for banning the member who posted it.
If you really have ‘long paths’ in your music hierarchy, then simply eliminate some of the folders. Artist <folder>, Album <folder>, Track Name <files> is all you need. Period. No ‘tool’ necessary.
i have same problem. Long Path Tool helped me in this situation. http://PathTooDeep.com
