Big files do not copy onto clip+ 4gb
I am getting something about semaphore time messages if using Directory Opus or “path is too deep” (regardless of the folder) when using Win XP Sp3’s explorer.
I have tried copying same file onto sony nwz-b 143 - no probs.
big here means 600 mb. smaller f.e 140mb - no probs.
Has anyone encouter such issues? I guess it is not normal for a usb storage.
pls help.
Hello
you are welcome here
with the help of long path tool you can solve your problem.
Long Path Tool is a best software to solve this issue. It Works perfect upto now as i copied more than 50 GB of data, more develop with data transferring progress bar will be more attractive.
Semiphore errors are the result of some process that has failed and crashed a program.  Security software, malware and viruses, disc errors are common problems.  Search the internet for “semiphore timeout errors” for more suggestions.
