Can anyone please explain this problem?
I’ve read up on it thru Google and seems to be a ‘maximum 255 characters’ type error
where Windows XP can’t copy anything over that limit.
Thing is - as an experiment - I put a file at the root of my hard drive, in C, where it cannot
possibly be over that limit and still cannot copy to the Music folder of the Clip.
I set my USB mode as MSC.
Can anyone shed any light on this? A workaround?
After an hours’ reading/messing about, I still have no music on my new toy! WAAAH!!
Any info gratefully received, thanks…
NumptyDumpty
Change the filename to something really short --1-Song.mp3 or something–and see if it likes that.
Hello
long path tool is the best solution for your problem. try it and solve your problem.
______________________
It is very best software for copy, delete, long path files. Please try “Long Path Tool” program. Thanx
I solved my problem using this tool “Long Path Tool” !
Software shills, go away.
You can use “Long Path Tool”
jk98
July 19, 2015, 7:13pm
9
I guess the path on your player may be too deep?
Hi all, I have been suffering from accessing, managing and even renaming files
>>> that have more than 255 characters over a long time. I have tried various ways
>>> but failed. Then I have searched this problem in internet. Then I have found a solution. This software is very easy to use. Named Long path Tool.
Yeah it can be a real headache, I tried LongPath Tool Program which helped a lot.
