How would you fix a sansa clip if you had dropped it in water?
Try to drain as much water from it as you can, then put it in a container with some dry rice for several days. The rice will absorb the water.
And don’t turn it on until you take it out of the rice . Water+electricity=bad.
Or if you’re not into rice, just put it in a warm place to dry out. We’re talking days …
Still; don’t put it in too hot place like owen set to highest temp or on any kind of heat source. I also wouldn’t expose it to strong sun for too long.
2 words:
hair dryer
