I have exactley the same situation. 1TB SSD with original cable (includes USB-C to USB-A) overheats quickly, but if I use my phone charging cable, it just warms up a little.
I connect it to various ports and OSs without issues, but I have noticed that disk (1 TB) overheats if I’m using original cable (which includes USB-C to USB-A adapter) but it just warms up a little (which is expected) if I’m using my phone’s charging cable (without adapter)
For the 4 possible cases, there is 1 case where the drive does not get detected.
Not in Explorer, Device Manager nor in Computer Management (using Win 10).
I can hear the connect/detect sound but device does not appear.
This only happens on a particular USB-C port on my computer,
the other port works in all cases. If I use a different cable (not from SanDisk),
I connect it to various ports and OSs without i Audacity Find My iPhone Origin ssues, but I have noticed that disk (1 TB) overheats if I’m using original cable (which includes USB-C to USB-A adapter) but it just warms up a little (which is expected) if I’m using my phone’s charging cable (without adapter)
all 4 cases works in any port.
I too have this issue with my 2TB SanDisk Extreme Portable SSD. I have barely used it. It connects then once I access it, it disconnects, the end in the drive is the end i have to turn around. Or press in harder and/or set drive in a position on a table until it finally works. If I accidentally touch the drive or cable I lose my connection.
