Hi, I lost the cable of my SSD. I used another ordinary phone cable but the SSD isn’t even detected. Does SSD work with ordinary Type C connector or is my SSD just not working?
Thanks for your help in advance.
Some phone cables are charge only and lack data pins. Try a normal data cable.
#SanDiskUserRewards
SSDs typically work with ordinary Type-C connectors, but compatibility can vary. It’s possible that the specific cable you used may not be compatible or faulty. Try using a certified USB Type-C cable or the original cable that came with the SSD to ensure proper connection and determine if the SSD is functioning correctly.
If you are looking to retrieve lost data, we suggest trying out EaseUS Data Recovery Wizard. This trustworthy and user-friendly software offers advanced recovery capabilities and supports multiple file formats and storage devices. It comes highly recommended by many.
