c240
My computer won’t recognize my sansa c240 and it was just working the night before. so what’s wrong?:robotmad::womansad:
What USB mode? What OS?
USB
nEver mind
Make sure you’ve installed the software first.  Then, on your mp3 player, go to Settings, scroll to USB, and make sure that ‘Auto-Detect’ or ‘MSC’ is selected.  If that doesn’t work, try restarting your computer and starting again, or sometimes the computer just won’t recognize it the first few times around.  Mine does that sometimes.  Also, make sure you have it plugged into the right USB port.  There are two common kinds: USB 2.0 and Firewire.  Most common are USB 2.0 ports, so if the port on your computer isn’t marked in some special way, it’s probably 2.0, which is what you want.
