*** i dont think i saw someone with the problem as me***
Hi i was adding songs and when i disconnected it,
it froze for a moment and came back up showing corrupted song titles with ‘unknown’ artists.
so i formatted and after that i cant add the files anymore.
Even if i do the screen says “synchronizing do not disconnect” but takes forever.
i tried disconnecting it (which i think is the main problem) then it turns on fine
(not fixed; i meant not frozen) but still have no song.
i dont think it’s a memory loss since the computer does reconize the device
and sys info says that the capacity is 973mb and free space is 973mb.
when i turn it on, it says “nomore space in DB please delete more than 4mb”
I tried putting it on MSC but when i explore the folder it says “unreadable”
and when i try to format it in MSC mode, it says “format was unabled”
Also there is no problem turnig back on but when i try to pull out the list (like song list)
it freezes and doesnt do anything. so i have to pull out the battery.
what’s the best solution?
i dont think it broke down completely.
how do i reset the device at least?
p.s. will the firmware solve the problem? c
cuz i do have the firmware but have to put it on RECOVERY MODE which i dont kno how to.
Message Edited by fab9107 on 10-10-2009 09:28 PM
